Hello everyone,
Watkins Bengal Model M Serial M1D1312
First time Poster and first time hot tub owner,
Just picked up a free spa It needs some work But the tub cover and outside look great for the year, it must of been in some sort of shelter.
I have powered up the spa for a couple seconds to see the circ pump turn on board light up and the turned jet pump on for 1 second to see where Im at with the electronics before investing time in the leak repair. Everything seems to work fine. I did not get a meter on the heater to test as I did not want to run it dry for long. (Spa was on for 3-4 seconds)
the tub was not winterized and the gentleman I picked it up from stated he already found the leak and removed the foam and cut out the Check valve. Im looking for a plumbing diagram for this tub to better help understand where all pipes run and what they are used for, Also to help identify possibly leak areas in the future before having to remove foam.
I am Also looking for a wiring diagram for this spa as I will be converting to 220.
My thought is to fix the already found leak, Fill the tub turn it on, Monitor for other leaks (I am already assuming the worst) and make sure all electronics work. once spa is tested and working correctly put it in its permanent spot. (currently its in my shop)
Is there a way to test the heater while the tub is dry?
The Tee is 2" ID and 2.25 OD with a 1 inch ID and a 1/4 inch barb the Barb looks like it might have been drilled and cemented. Is there a direct off the shelf part for this tee with barb? or do I have to make my own. Im having trouble locating the part.
Is this the correct check valve? https://backyardplus.com/parts/71980-water-check-valve-1-1-2-inside-diameter-2in-outside-diamter/
the broken check valve is 2.25 ID on the Tee side and 2 inch ID on the opposite. the tee is cemented directly into the check valve.
Can the Flexible PVC be cemented with regular purple primer and PVC glue? If not what do you suggest? it looks like the manufacturer used some sort of cement I am not familiar with using with PVC
Any tricks, Tips or suggestions with diagnosing and repair you guys have would be greatly appreciated. As this is my first time working on one. Any pictures or information you need I will be glad to post.
Thanks everyone
picsofspa.zip
