Thanks for responding.
Everything was working fine till i replaced two O rings. Fixing that did cause a significant leak (about 200 mL/min) at the suction side of pump - I await the part. When I refilled the spa, turning on the spa pump tripped the GFCI.
New pump connector plug is on order to replace the damaged one.
The GFCI is on the spa pack (photo). A new one is on order.
The circulating pump and heater appear to be functioning fine. I ran them all day yesterday - the water came up to set temp.
If I turn the spa pump on, the circuit trips after a few seconds. UPDATE: today it ran for about 10 s beforeit turned it off. It does suck in air at the leak. The flow out the jets was very weak. The pump tripping the GFCI and the arcing legacy found on the pump connector are what made me suspect a potential pump electrical issue. But would air infiltration cause a pump to trip?
I did replace relays a few years back. In practice, when the pump is activated the relays for the circ pump and heater should turn them off. I have not tested them yet but, again, they were working.
Hopefully attached are the board and the compartment pix. I do not have a circuit diagram.
