Yes, definitely leaking at two of my three pumps. What’s weird, we drained, cleaned the scaling, refilled, and I added 5lbs dry acid over the first day after filling. Barely lowered alkalinity into my testing range (250 and under). Next day, we added 2 cups muriatic acid. Then overnight, the water level is at the bottom of the skimmer when opening pool . We did not have that drop in water before, prior, we thought we were losing to evaporation. So we opened up panel, saw leaking. Maybe scale around seal dissolved from muriatic acid? Caused existing small leak to leak more?
so now we are just going to try to keep things from going green, until we can get it serviced.
my big question has been, pool site says add 4.5 lbs of dry acid to my 2200 gallons water, to correct my hi-alk. Add half recommended amount, But don’t add more than 1 cup at a time. And then I can’t make headway. I am having more success with muriatic acid, my ph is not dropping below 7.1, even after 2 cups added. My alk is dropping.. until I refill the pool! Adding more alkalinity! My well ph is 7.2, alk 250+. So now we plan to add acid, just to keep clear, sanitizer when using, until leak fixed. Then back to proper balancing attempts.
