I can see water movement (tiny bubbles) in the clear vinyl hoses on either end of the heater manifold, and can hear/ the water movement as well.
When I swapped out the pressure switch, got a good 3' stream coming out of the fitting hole, and no bubbles were noted on either end of the manifold.
I replaced the assumed original(?) flat, square, switch with an adjustable Tecmark 3902 unit recommended by a tech friend out of the area.
Sending that back assuming/hoping it's defective and hoping to source an "OEM" one from a local shop this AM. (The control panel cover won't fit over the Tecmark unit anyway, so best to spend the $ to get OEM style)
Finally figured out how to attach, so removed switch, installed Tecmark replacement, and video below of behaviour
https://www.youtube.com/watch?v=pUEvIiLtc5M
