Ok, now for my second question. My 1996 Dimension One Triton Ultralife (which I recently got used and nonfunctional) is somewhat up and running now. I am still trying to decide on which way to go as far as replacing the control system, but at the moment have it set up to run the pump on high when you turn the GFI breaker on. Since my wife is about 6 months pregnant we aren't worried about heating the thing right now anyway. The 90 degree temp the outside air heated it to is fine with us and safe for the baby...
I did not get a manual with this tub, and the D1 guys don't go back far enough to provide me with one. There is no air pump on the spa, but there are 2 vertical tubes in the pump cavity that have check valves on them. Would this spa have some kind of venturi system to allow air to enter through the check valves into the jet system? Is there any way to control that feature? Are those tubes where you'd connect an air pump if I were to want to add one?
There is one rotary valve knob topside that switches between some of the jets, but that is all I've fou so far. I also discovered by accident that the ring around the jets lets you turn them on and off. I'm a total newb to spas, so thanks for the help!
Thank you,
Jason
