Hi all,
I've been troubleshooting this issue for over a month now to no avail. The problem started when I noticed the hot tub (Masterspa ls850) was not heating. On examining the circuit board (ms8000r1a 53232) I noticed that one of the components on the board had clearly burnt out. I replaced the board with a new one (balboa el8000m3 53858) as well as a new heater (both old and new heaters are 5.5kw 240V with M7 sensors). After replacement, I began getting errors indicating flow, dry and HFL. I removed the filters, but it did not resolve. I checked for airlock but only water came out of the bleed screws on the pump and the various joints I loosened. I'd also filled the tub directly via the circulation inlet. The inlet has strong suction when the circulation pump is active and I can feel strong flow at the outlet. I replaced the circulation pump with a similar model (1/15hp, 115 volt) but continued to have the same issues. I’ve used an inspection camera to examine the pipes from the inlet to the heater (all clear) and from the outlet. There are no perceivable obstructions. The only part of the plumbing I can’t completely examine is a small PVC loop where the ozone would be injected (ozone was removed). I've been unable to find documentation for the specific version of the el8000 I have, so I've tried various dip switch combinations but none seem to make a difference.
