26 -
Days Won
1
DesertRat77 last won the day on January 23 2023
DesertRat77 had the most liked content!
High Desert, CA
DesertRat77's Achievements
2
My system is apparently "ozone ready" (2017) but I'll go confirm the little plugged spout area coming off the water line tomorrow before I order. And I'll see what kind of cords I have first. Man every time I think I'm ready to order I find something else I need to check. I've learned so much now though, no more spa techs coming here, it's on!
Oh this is very helpful. Posted my last comment before I knew about your post. My spa currently has 1 pump with 2 settings (low/hi) and color changing LED lights (can't stand, never use). I would love to upgrade to include a blower - I know "turbo mode" (assuming blower?) was an optional item on the original Beachcomber spa model I have which they did not include. I know the one with "turbo" is an entire different board/pack so its probably a can of worms I shouldn't worry about.
I have now discovered the bottom corner of the Balboa board is labeled VS500Z. I believe that board has now been discontinued. I wonder if the 2 replacement boards I got were part of the discontinued lots. So it seems like I should be able to get a spa kit which would replace the VS500Z & not worry about any Beachcomber branding. But some sites say the VS500Z board has been replaced by the VS501Z so I was going to order a spa pack based on the VS501Z but other sites say the 2 parts are not compatible. I worry if I order anything else labeled VS500Z it will end up melting again.
Hi again. Last question I promise! My board is labeled model VS612 and for the life of me I can't find any spa packs that say they're compatible, they all say VS500 series etc. I can't find any reference anywhere on Balboa's site or elsewhere about the VS600 series. Mine says part number 55263-03 which I also can't find a reference to. Am I safe ordering the afore-linked "Balboa BP7 5.5kW Spa Control Kit"? Any upgrades I can/should make while I'm at it? (I should mention the only places online where I can find references to the Balboa VS612 board are posts & reviews about it burning & melting 😂)
Ok thank you. Yes it was the same tech both times. There's only 1 spa place within an hour of the tiny town I live in & he was their guy. I'm not even sure he's still there since it's been 1-2 years. I can call a place in a the city an hour away & pay a surcharge for them to come out here or I can DIY it. A little intimidating to DIY though so maybe I'll try to find another place. Edit: I see a spa pack comes with the board as well so I'll order one today. Thank you all so so much for all the help, I was really lost on this & you helped me narrow down what it could be so it hopefully never happens again. 🙂
@chrispomeroy I didn't see any evidence of water or drips inside, everything was covered with an even light layer of dust. The dust in our area definitely has some iron so I suppose that could be possible. Its odd, most homes in our area are short term rentals (not ours) thus many have hot tubs but I feel like I'm the only person with these continuous isolated problems so I don't think its the environment. @CanadianSpaTech I'm not sure how to tell - would there be a discoloration outside or do I need to take it apart to see? I contacted the spa store here but no word back yet.
Hi, thanks for your patience everyone. We confirmed it is the one on the left labeled "Dryer Spa Dryer" - turns the power to the spa breaker box off and also the dryer. No idea why they are tied together like that. I tested the power going into the spa breaker box with the spa/dryer switches turned off, then on. I have 119v coming in at each of the 2 black wires under the GFCI with those switches on & nothing with them off.
I'm going to have to get those eggs ((shudder!)). I can try to label them tomorrow to figure out what is what. Its long overdue. I found the original photos of the main panel from our home inspection when we bought in 2018 (below). So the "spa" on the right is original and the "spa/dryer" on the left has since been added - not my handwriting. I'd bet a million dollars my HVAC guy changed some things around in there when he installed the central A/C as it seems like that would require an equivalent power draw. Maybe I should call an electrician again. But let me know what to check with my multimeter & I'll do it. Thanks so much for all the help.
