Hi Everyone,
Would be grateful for any assistance. I have a Hot Spring Hot Spot tub (bought around 2015 )that shows two lines of dashes like this on the read out ===== and its causing the tub to not heat up. I checked the manual and it says that 'Pressure switch is open and should be closed'. I checked my tub and my pressure switch is a small box with out any turning device on it like in the picture below.
Another option in the manual says that the filter could be clogged. I haven't hosed the filter down in a while but it doesn't look clogged. The white filter pieces are a bit yellow but there are no major blockages in the filter.
Any advice would be greatly appreciated. Id rather see if someone has had the same issue before calling a team out to fleece me. :-)
