Hi - newbie here.
We have a brand new hot tub, 290 gal LifeSmart tub. After hook up and initial fill using a hose end filter due to well- water was clear looking and all seemed good.
We added Spa Metal Free by Natural Chemistry, put filter in and turned jets and heat on. Within 5-10 mins the water was a light green and then turned mostly yellow with 15-20 mins.
We did a Spa Purge (foaming and a bit reddish brown flakes appeared), filter also orange/red color. We then drained tub and rinsed filter. Next day, we filled tub again using a hose end filter. Again, water was clear. Added Spa Metal Free and began circulating and heating the tub. Again within 5 mins water in tub turned greenish to yellow.
My question is, could the Spa Free Metal be causing discoloration? The plumbing in new tub contaminated? Or is our water (3 ppm iron well water) clear and then turns yellow upon heating/aerating?
Anyone have any ideas. My plan now is to shock to see if the yellow goes away. Ph is about 7.4 and Alk is 115-120 per pool store. On test strips, alk looks lower.
