Powered off with solid HH on display, waited 5 mins then powered back on. Went through prime OK, low speed pump kicks in then set display to St at 100 with current water temp at 71. It ran for a few mins then shows water temp and Sn alternating. I've never seen Sn code before. Heat light is not coming on this time. I ordered the sensors just in case. When you denote risky changing full its more about controlling the flow all over everything than damage to heater correct? I live in an area that has ALOT of lime. I drain and vacuum my home water heater twice a year or it builds up to the bottom element and shorts it out. I use a prefilter on the water in the spa to try and cull as much of this as possible.
