You should replace the entire drain system if you already have a leak. Of course, this will require a lot of money. But I don't think you should wait too long. I see that you already have the first signs of mold and other dangerous growths on the surface under the drainpipe. You may call oceanside water damage repair specialists to clean up the leaks. Of course, before that, you definitely need to replace the entire system, as I said. You can only do it yourself if you understand plumbing. Otherwise, it could happen again. Who installed that drainage pipe for you? The entire drain system's cabinet is also irreversibly ruined and infected.
