Older 2005 Beachcomber 578 blew the 2 30amp fuses on the side in the winter and just getting it going again. Yes I winterized it after.
Everything else works fine but the circulator pump will not run.
Troubleshooting
-Ran a 120 to pump direct and it worked (its a 230)
-Ran a 230 to the pump direct and it worked
-Replaced the pump same result not a kick
-Multimeter at board 120 at blue to ground and brown to ground
-Multimeter at pump 120 at each post to ground
-Multimeter on board blue to brown 230
When I plug the pump into the main board I can no longer get 230 on the board touching brown and blue meter goes to zero. I still have 115 at ground and blue/brown on both the board and on the pump but can not get 230.
Scratching my head thinking it must be the board
Suggestions?
Thanks
