Hello I have some problem with my spa:
Jacuzzi Model: E781VM maax spas
Controller: Balboa 760E
GFCI: hager model CDC440J.
Lights controller: SloanLED LiquaLED Control 40
1.
When I dont use a lights, heater functionally normal with jets etc.`
When I don`t use a heater, lights functionally normal with jest etc.
When spa lights are on and I switch on heat, trips GFCI (hager model CDC440J).
I try to disconnect a light from mainboard but it`s still the same, when I switch lights on [with disconnected controler or not] when heater is on, GFCII is triggered.
please, have you got some ideas what to check?
I have tried: disconnect light controller from board, disconnect ozone/uv, disconnects lights from lights controller.
2.
Circulation Pump on standard mode:
[in fast speed] functional normal
[in slow speed] stopped after 10s-10min, DR/LF fail.
