I am replacing my century two speed pool pump motor with an AO Smith Century UQS1202R uprated 2 speed motor. All is well except that the new UQS1202R motor only comes with three wiring terminals, L1 L2 and Ground. And that is confirmed by the label. There is no common terminal. The two speed pump I'm replacing had a common terminal which I need to run the two speeds. And when I go to the AO Smith wiring guide, they show a common terminal for this product but in real life it isn't there. http://castellanomotors.com/techinfo/connect/aosmith/aoguide.htm
I'm running a Jandy Aqualink controller with a relay for high speed and a second relay for low speed so I need the common wire set up to send power to the high speed side and the low speed side of the motor.
What do you suggest?
Thanks for your help.
