Does anyone have any experience with this product? The manufacturer states:
Hi, we are the manufacturer of the Leisure Time pH Balance. Before using this product, make sure that your calcium hardness is no higher than 150 ppm and that the pH is between 7.2-7.8. If the calcium hardness is higher than 150 then you will want to use pH Balance Plus instead however if you are at 150 or lower then this product will be best for you. Get the pH into the range if 7.2-7.8 if it is not already in that range, and then apply the pH Balance to help hold your pH in range between refills.
I have used this product before and it works incedibly well, I stopped using it due to issues with Eczena and trying to determine what made me break out so elimated this but going back to trying again. I most curious if @waterbear can teel me how it works chemically?
