Juliesspa
Juliesspa's Achievements
1
  1. We inherited a QCA spa when we moved into a new house this summer. It had been working just fine and we really enjoyed using it. There is a Gecko Aeware In.Clear bromine salt generator installed on it. This last week we cleaned the system, drained the spa, cleaned it thoroughly, then refilled it. We also cleaned the filter. We balanced the water and then added the Bromicharge as required (6.6 lbs - we have a 550 gallon hot tub). We have the maintenance mode set to 23 and the filter hours to 9 (which is what we had been using all summer and fall). The bromine will not generate, however, and we keep getting errors. Sometimes it is an ERR error and sometimes it is a LO err. We can't even push the "boost" button, as it is flashing "ERR" or "LO, " nor can we even turn the system off without pulling the breaker. When we run the diagnostics, it will go through them and the leaf and the Lo lights will light up. The manual says that both error messages require that we add more Bromicharge. However, we have added about another 2.5-3 lbs worth and it still is saying the same thing, and I am afraid we have just dumped even more money down the drain. Does anyone have any advice on what our next steps are? The manual doesn't give much more guidance. I've contacted Gecko Alliance through the support website but no one has written me back, and I can't find a phone number. The system seems to operate just as it did prior to our cleaning/refilling, other than the bromine not generating. Here is an example of the ERR message. I
