Hello fellas, I also have the tiger River Spa I think 12 to 13 years old. It is a Caspian. I have it inside a sunroom and just noticed water seeping out Underneath opposite side of equipment or pump compartment. There are no noticeable leaks or drips inside the pump compartment area.. The leak seems to be very slow. I am going to lower the water level below the first set of jets then see if it stops. And go from there. I would like to empty the hot tub and raise it up and look underneath to see if I see any water stains, or water spots that might help determine where the leak is coming from. But before I do I might as well lower it a little at a time and see if that helps isolate the issue. If You fellows have any other thoughts or advice - much appreciated. Thanks John
