I did the test you said tested from the low to the common and the high too the common when o do while the tube is running the high reads 123 Volta and the low reads 20 Volts at the same time I click the pump button too kick it too high speed and the relay clicks right back off tried it with the pump hooked up and in hooked and got the same readings when the pump turns on. It’s like it’s fighting it’s self like the power is drawing the pump slows down below are picture of the board and the whole cabinet it dosent have a wiring diagram but the circuit board is a mini max 1503d75b
