2012 Hot Springs Grande leaking from the drain port in the moto massage compartment. Both rear corners removed to gain access. Siding is very brittle prying off. Foam removed with screwdriver and pulling with hand to get to the drain nipple. The drain hose with hose clamp was broken from the drain nipple. I think they make a replacement kit. I "temporarily" stopped the leaks with some things I had laying around to shove in the holes. I'm thinking this drain removed water from the motto compartment to avoid freezing up after draining in the winter or to get 100% water out the hottub. I plan to run a self 5/16 hex head x 3/16" x 1" tapping screw with teflon around the threads thru the drain hole nipple from underside. Then run a screw into the clear drain hose. Hope that works.
