Thanks,
1. Filter out
2. Water level good
3. It's a new flow switch
4. There's a 2 prong connector that connects to the board - not really possible to just disconnect 1 wire. If I pull the connector off and power on, the pump comes on. Seems like good pressure at the jets
5. On an earlier post someone shorted the two flow pins after the pump started - the heat came on and the error message went away. I tried that using the old connector and shorting the wires - no change
