Razzledazzle668
Razzledazzle668's Achievements
  1. Wow and that's what I was afraid of with mine lol, good to know the estimated repair cost! I wonder if it Make more sense to destroy the side skirt to be able to repair in place but wasn't sure what options are to replace it
  2. 👀 not gonna lie I tried the epoxy on a few jets last year when the leak was a little slower , mine looks good though 😉
  3. Have you found a particular brand of marine grade silicone that works best? 3M?
  4. Thanks! Really appreciate this info, you too @RDspaguy
  5. Correct , back wall behind pump and control board. The spa is a beachcomber similar to this with the slats that are apparently unremovable (shitty for me)
  6. No worries thanks for the reply. It's all coming out of the part that's circled in the photo
  7. Thanks, I took the front panel off today and there's this small spot at the back where all the water is coming out of , any idea what this is? video attached. IMG_2182.MOV
  8. Hello it appears as though I have a leak right where the filter housing sits on the surface of the hot tub (see pictures attached) it’s either this or the leak is coming from the upper part of the 2 jets in the corner shown, I just think the waterline really indicates it’s more at the filter. My question is am I able to remove and reseal this portion from above the tub or do I need to get under it? My understanding is there’s a bit nut below so if I twist that top in reverse will it loosen that nut? Will I be able to retighten? Is there an o-ring there or do I just silicone it? Are there any videos out there that explain this process? thanks in advance
