RDspaguy,
You are the SPA GURU! You nailed it. Installed a new set of Balboa M7 sensors from Spa Depot. Spa powered up normal and went into PR. Selected pump one and it came on low speed. New upper spa panel, from My Spa Parts Store, indicated temp at 65 deg. Four min later the heater indication came on. Selected pump number two and it came on. Selected both pumps to high and no issues. 10 hours later temp indicates 102 deg and everything working great.
We looked at new spa's in the range of our current Marquis Epic 2009. They ranged from $13,000 to $15,000. Putting a little research and $1,500 I replaced one pump with improved model, new temp sensors, control panel with dead display with new LED version, new pillows and most of the control valves. Its like a new spa.
Currently researching ozone generators to replace the old Marquis. Not many good reviews with short life span being the biggest gripe.
CanadianSpaTech, I do appreciate you responding to my post. Thank you.
Thank you Pool Spa Forum for this site and again to RDspaGod for solving the malfunction.
Mitch Forry
