Hi guys, I think between you, you have given me sound advice I have followed your suggestions i:e changed over to 50hz and removed jumper from J24 & put it on J6, the circulation pump is running As it should now No flo errors. I can’t thank you enough for your advice. Now I can enjoy the spa
well done
Right, I have changed jumper to 50hz also taken the jumper from j24 (orp enable )& put it on j6, I’ll see what happens now & let you know..... Fingers crossed
i’ve noticed a jumper on J10 which says enable pump 3, but i do not have 3 pumps only the circulation pump & a 2 speed pump, i wonder if the previous owner had work done on this spa & used a similar board & made it fit ?
i have noticed that when spa gets up to the set temp the circulating pump shuts down then there is a quick flo error then that disappears and the spa displays just the temp of the water i thought the circulating pump should run 24/7 ? when looking around the control panel there was a temp sensor just hanging from the box,i have since found out it should be clipped to the heater tube. it has never been clipped to the tube since i have owned it.
Turned off spa checked continuity, none. I Done This when spa was running ok,
I will try again when I get the flo error & the circulating pump has stopped running.
Hi, this was the control panel that was on it when i purchased it 5 years ago, i don’t know if the previous owner had work done, but it was working fine, pic of circuit board
thanks guys for all your help much appreciated
When I set the temp higher than what The water is say 35 to 36Deg It heats up to that temp then I get a flo error and the circulating pump stops with just the temp showing on the panel, if I raise the temp it runs again till it reaches that temp.is there a temp control that is Connected to the circulating pump ??
Yes I tried that, it moves control of jet 2 & 3 to the jet 1 button which does the same as Jet 2 & 3, all the sockets on the control box have dedicated plugs that will only fit their right sockets,
