Odd, and hopefully better news on the leak.
I turned off the tub yesterday evening in readiness to drain today after work. 18 hours later and the sign of water from the base has almost completely stopped. Weather conditions haven't changed so its not a case of the water drying faster off the floor.
I've taken a reading of the water level as a reference.
Unless there is a further leak, this is pointing me to the circulation or heating system. I had checked both the circ pump and heater unit with no obvious signs. I did notice a slight leak from air divertor knob on top last night, but thought this only came from secondary pump and no sign of leak underneath.
I will recheck the circ pump and heater, but any other suspect parts of the circulation loop to check?
For my learning, what loop does the circulation take when pumping?
Thank you again for any advice and information.
