I'm hoping to get some expertise in troubleshooting my 2012 Calspa. I drained and refilled it yesterday after about a year of not being used. When I turned it on at the breaker, it went into priming mode on the display as expected, with PR displayed. However, I didn't hear anything at all from the motor. I pushed the jets button, but still no action from the pump. I did the same thing several times with similar results. I don't think it is an issue with air in the lines since the pump never turned on. I did a continuity check on all the fuses in the box and also checked the pump capacitors. Everything seemed fine. Also, I checked every cable I could see to make sure they were all plugged in and undamaged. I'm not very familiar with the inner workings of the hot tub, but everything looked clean, unfrayed, and there were no loose or disconnected wires.
Any tips for next steps troubleshooting? I'm thinking that maybe I should see if power is being supplied to the pump? I'm not sure whether it should receive 240 or 120.
