I have a Dimension One Hot Tub. I replaced the PC Board and the problem was solved - I now have heat and filtration. Once installed and powered back on, the jets wont turn off. Possibly I have a swapped connection somewhere but all else seems correct. Its reheating from 78 degrees up to 104 and I will shut off the power unless there is some mode I am not aware of. Pushing the controller for Jets only seems to switch from Jets 1 to Jets 2 and no off option. Does anyone have an answer on a possible crossed connection or solution? Thanks
