Hi
First off - thanks for any assistance/comments/help!
We just set up a an above ground Intex pool 15 x 42". After getting all level and straight - it took us 3 - 4 days filling because we set this up on a weeknight and we couldn't/didn't want to leave the pool filling while unattended...
I have to confess that we were in the water from day 2 - day 4 because it's been too darn hot here. Ok - now that the pool is filled (a few inches to go - but I think that is a good margin since it could rain that much in a day here depending on the weather and I don't want it to over-fill)
Time to turn on the filter and adjust chemicals - I turned on the filter Friday night and have basically let it run since. This morning I placed a 3" tablet of chlorine in a floater AND shocked the pool with one of those "shock" packets you can buy at WalMart - (filter running - water clear (always was) skimmer thing working fine...) I tested water pre and post - all stayed the same except the CL levels. After I put in the 3" tablet/floater - i didn't see any difference in the CL levels - I then added the shock packet (which I diluted in a bucket before adding) - CL levels went up to what looks like normal levels - 3-4 ... Six hours later I tested the water again - Hardness, pH, Alkalinity, Cynuric acid all the same - EXCEPT - NO chlorine???? What happened and what do I need to do -
Current levels before and after shocking and a 3" chlorine floater are"
hardness (200) ; Chlorine 0; pH 7.3 - 7.5 (somewhere in between the two on the dip stick)
Alkalinity 120; Cyanuric 30-50 (could be lower)
I don't want to over do the Chlorine - but also want our friends to be able to get into the pool (with me not worrying....) I hate over-chlorinated pools - so am relunctant to do anything without advise...
It did rain a tad - but not anywhere near the amount that could have changed the chemical readings - the pool is in full sun until after 3 pm - water looks clear and healthy - but I know chemistry - looks can be ...... Other than making a trip to my local pool store tomorrow - (which I can't do work-wise) Does anyone have a clue why the CL levels dropped so dramatically? Again - water looks fine...
Thanks for any help!
