Ok, So my wife decided we needed to get this used hot tub from her friend, long story short, I poured a slab and moved this thing to my backyard. Wired, and found/fixed leaks. Replaced 1 bad pump. (waterway executive 56 5hp Both are 2 speed.)
Ok, so no Idea of the manufacturer, Cover around the filters says "Phoenix Spas"
Control says Balboa
The Spa Pack is a VS501z by Balboa. The heater is an M7 style
SO... hopefully these are most of the details needed. I'm a plumber so I understand pumps and what not.
Issue #1 The pump connected to the heater, is that supposed to be the Circ or the Pump 1?
I would think it should be the Circ to move the water around thru the heater, but I'm not an expert. The new pump I installed was originally plugged in the Circ port on the board. However this pump wont run of the control panel.
I know the spa heater works, tested and had the spa up to temp at 1 point of time. Now its acting goofy.
I have no history on this tub, but know I can fix about anything with a little direction.
Any suggestions or ideas?
Jeff
