ANGIEHOST
ANGIEHOST's Achievements
  1. did you ever get this repaired? I have a similar problem. thank you
  2. hello, I have a Nordic Sport hot tub. I believe 2002. The control panel will go dim and when it does the only button that will work is the Temp Up button and it is what will turn the jets off and on. When it is normal lit the correct buttons do the correct functions. So you can't control the temp or light when it is dim. If the power goes out or your reset the power box it resets the temp back to 95. I also have noticed it is getting stuck on low jets and not turning off after the 20 minutes of circulation. Any thoughts on how to correct these problems. Thank you.
