Excellent questions. When I power up at the breaker, it goes thru a self test and then reads 104 for few seconds, which is what it is set at, then reads 115. I can change the desired temp up and down, and then it displays 115. I assumed that was what it thinks the temp is, but it could be an error code. No visible signs of a burned board. I do have a multimeter and will check to make sure both legs of power are good. I figured that since the pumps ran normally, the current was good, but maybe they run on one leg? As for current to heater, there is none, but I figured that was because it wasn't calling for heat. I'll take another look at the lights on the board and also check the incoming current and get back to you. Thanks for helping me think it thru. The Hot Springs dealer where I bought it went out of business last year so no one close to trouble shoot it.
