Hello.
I have recently bought a used spaform milano with one seized pump. after installation I have fitted two brand new pumps. One to replace the seized pump and the second to replace the 2 speed that was tripping the rcd. However it sttill trips the rcd with the new pump plugged in.
I have limited skills but I have tested the output on the control unit and it seems i have 240v supplied to both the high and low speed when the hot tub is powered.
With the said pump disconected it seems everything else works ok. blower fires up with 2 speeds and the jet 2nd pump also circulates. I also beleive that the heater is ok as I have checked the resistance and that shows around 19ohm.
More to do with the pcb me thinks,,,,, Upon removal I found that the relay that supplies the low speed to be charred the pcb and had a closed circuit.??? ok so on the pcb I found there to be a spare relay(Perimeter light ((not Used)) that I removed from the pcb and soldered in place of the low speed. thinking that I had solved I then reassembled the pcb within the unit and again has tripped the rcd.. Pcb removed again to find that it has also blown the replaced relay.
I understand that I will have to invest yet another £500 or so to replace the pcb If I cannot get this one working. Im seeking advise on the repair of the pcb or replacement of control unit and panel with a cheaper option.
Any help is more than welcomed and my kindest regards come forth to your response
