It all started a few months ago when my bearing started squealing in my 2006 Cal Spa. After taking the pump out and doing some research I learned that this was a "Dually" pump. I spoke to all the hot tub places and small electric motor places in town and nobody would rebuild it. They told me they were near impossible to get into and it wasnt worth their time or my money. Before retrofitting a new regual pump into my Spa I decided I had to at least try and take this thing apart. Long story short I got it apart with no issues. I replaced both bearing myself and bought a new Impeller because one of them was starting to crack and deteriorate. I also replaced both the shaft seals since I had it apart. The pump went back together easy and I put it back into my Spa. Plugged everything in and there you go, Hot Tub back up and running. No issues.
I should also mention that I replaced the top side panel and the main motherboard about 5 months ago as well after getting some errors that after searching told me I had either a bad top side or a bad motherboard so I just replaced both.
Everything has been working fine for 2 months until the other day when I went out to my hot tub and removed the cover only to find the temp at 90 instead of 104 and it wasnt heating.
I hit the Jets button and the motherboard relay clicked but nothing happened. Pressed it again and they came on but on Hi. No matter what i did the low speed pump would not come on but the hi speed worked fine. The massage seat jets also worked fine. Randomly pressing the jets on and off after sometime and for whatever reason I got the low speed to work and it started heating.
Once it reaches 104 it shuts off but when it goes to kick in to start heating you hear the relay click, the pump hums for about 5 seconds, then stops. From here your back to fighting with the Hi Speed until the low speed works. The only sure way to get the low speed on everytime is to catch the tub when it wants to heat and the pump starts humming and while its humming you hit the jets on Hi, then again and it will go to low everytime.
On top of this if I kill the tub at the breaker and reset it when the tub comes back on it reads "01" for a few seconds, then reads the current temperature before it trys to kick on but it wil just hum. Then from here if you catch it in time you can hit the jets button a few times and it will go to low.
As well as this when its acting up it seems as if you have to hit the Jets button twice for everything. If its on Hi and you hit the Jets button it will not shut off, nothing happens. Only when you press it a second time will it shut off. Then if you hit it again it will click but no low speed, and a second press will get you back to Hi Speed.
I read somewhere that there is usually a Start Capacitor and a Run Capacitor. I just took my pump out today and opened to the two covers to check the capacitors and they both look fine although perhaps they could be damaged in the inside. I also read that I could have fried my Relay on the motherboard that controlls the low speed pump to kick on when it needs to be heated. This would be odd since my board is only 5 months old.
I took my pump apart today real quick to make sure nothing was lodged in the impellers and that everything moved freely. It seems to spin relatively smooth and without resistance.
Any suggestions would be greatly appreciated. Im going cracy here, haha.
Thanks
Kenny
