I got a free hot tub from my neighbor who was throwing it away. It was tripping the GFCI on power up consistently.
I narrowed the problem down to the heating element. Replacing it fixed the tripping, and I needed to replace the transformer and pressure switch to get it to heat.
So I turned it on and watched it for a bit, looking for any leaks. When everything looked fine and operational, I closed everything up and turned it back on for the night. I made sure I could turn the jets on and off, the lights, and set the temp to 100F. Next morning everything was fine, the hot tub was at 100F and idle. I was watching it when the filter cycle came back on, considering getting in, when the pump starts sporadically coming on and off.
It's a two speed pump and I mean the high speed (jet speed) would kick on for a second, then shut off and repeat that infinitely. The control panel was unresponsive. I watched the inside of the box while this was happening and the relays would kick on in series 1-2-then click off. Over and over. There was minor sparking and arcing at the magnets while this was happening, but I think that is part of normal relay operation.
I thought maybe the condensation from the cold water heating up in the pipes maybe got on some of the controls, or the humidity rose to the underside of the panel or something, so I shut everything down. A couple of hours later everything was working normally again. This lead me to believe it was moisture related.
So I made sure everything was functioning normally, and started to cover the complete underside of the panel with dielectric silicone, and while I was at it, redid the seals on the top side as well. I wrapped the cords that plug from the panel to the circuit board with a shop towel and put some more silicone around the socket. I am pretty confident there's no water getting into the control panel or where it plugs in now.
But the problem persists.
If I unplug the control panel everything works fine for hours on end, but there's no way to turn on the jets or change the temp. Plug it in and I get the surging. I really don't want to replace a $250+ panel, I already put $100 into the tub, I could of probably converted the whole thing to pneumatic at that rate, so if anybody can give me a fix or workaround I'd be really grateful.
Its a Marquis "Leisure Series" panel, with a Balboa LZR1U circuit board.
I should add that letting the hot tub run with the control panel unplugged (so not even resting) for an hour or two, then plugging the panel back in will work everytime, for about a minute before the problem returns. I can adjust the temp and turn the jets on and off during this grace period. I've tested the water temp with an infrared gun and the panel is displaying the temp accurately and there are no messages.
