My 1999 Jacuzzi Z135 keeps shutting itself off. The control panel only has a red light for status, so i don't get any error messages other than the red light flashing. The hot tub will get hot and will run on high for as long as we want it to, but it turns it self off when we are awag from it. Also, the circuit breaker has never popped. It is wired for 220v.
The owners manual says that it could either be the temp/high limit sensors or the pressure switch.
I have already replaced the temp sensor set and the issue is still occurring. I function tested the pressure switch and everything seemed okay. It reads a steady 0 ohms with the pump on low and when I unplug it from the circuit board the pump still runs and the heater turns off. I have also checked and made sure that the filter is clean.
And if it makes a difference, we don't have a propper cover for it. I simply use a tarp that has been folded over several times. It has never been sucked into the skimmer.
Can someone please shed some light on what might be causing this issue.
