Hi All,
Nice to find a forum devoted to hot tub water chemistry.
My wife and I purchased a 300 gallon hot tub 3 years ago, and we have it on our back porch in upstate NY. We love it and use it all year.
Cutting to the chase, I started off using stabilized dichlor with Clearwater Blue, Oxyspa and the tub's ozonator. I was religious about chasing pH, alkalinity, copper, residual chlorine, etc., and could not figure out why, after 30 days or so, I would begin having bioscum, foaming, clouding and itchy skin on arms and legs behind the elbows and knees. I was following all instructions religiously.
Then I did some web cruising and found that the cyanuric acid (CYA) that is meant to UV stabilize the chlorine severely diminishes chlorine's sanitizing capability as the CYA builds up. We rarely use our hot tub during the daylight hours, so we really didn't need the stabilizer, but couldn't find an unstabilized chlorine product locally.
So I purchased test strip that had CYA on it, and actually began using CYA levels, foaming frequency and any signs of itchy skin to determine when to dump the tub. Primitive to say the least.
I went back to the web and dug deeper for a non-stabilized chlorine product and how to properly use it. The first thing I changed was to nicely ask my wife to back off on the skin care products on nights that we are going to use the tub. That was tough, but we humidify the whole house now and that has helped her to use much less skin cream.
My next move was to an unstabilized 29% lithium chlorite dry granules with 35% active chlorine . Go easy, as you need less than one ounce to sanitize a 300 gallon hot tub. In has very little chlorine odor, dissolves instantly but the chlorine residual drops sharply after doing its job. Some people say that it's expensive. A 5 lb jug has lasted me from last June until now, and has another two months worth of product remaining. I stopped using dichlor except for when I put new water in the tub. I use it then for the first few sanitizations while monitoring CYA. When the CYA hits the minimum ppm, I stop using the dichlor. This recommendation came from the web, as it leaves some stabilizer in the tub.
The next thing I did was to stop using the Oxyspa. Haven't used it in over a year. I continue to use the Clearwater Blue kit, which is a copper ion mild sanitizer and mild algicide. The Blue keeps working after the lithium hypochlorite residual drops off.
I also upgraded my ozonator to a bigger unit. Here's the recipe that has been working for the last year and gives us a long-lasting, clear, clean and non-itchy hot tub (the wife thinks I'm a hero!): 1. Fill hot tub with city water and use the Clearwater Blue product per instructions. There's a filter prep step with it, so read the instructions carefully. 2. Use about half an ounce of the above lithium hypochlorite product after each soak, and turn the jets on high with no air to mix for 10 min. Make sure you leave your air OFF when the tube is idle, as it can affect water pH. 3. Use a pleated, antibacterial tub filter, and take it out and clean EACH PLEAT by hand under your shower head or sink with sprayer nozzle no less than once per month. Let filter dry and rotate in another, clean filter. This is important...you don't want to leave even one pleat with scum in it that could hold hibernating bacteria even when the filter is dried out. This effort alone prevents re-innoculating the hot tub with bacteria. I no longer use a trisodium phosphate filter soak. 4. Every time you rotate filters, add 5ml of Clearwater Blue copper ion and re-check copper ion levels 5. If you don't use the tub for 2 weeks, add about half an ounce of the lithium hypochlorite and mix per above. 6. Keep a surface scum filter inside your skimmer. I use Zorbo...and change it about every 8 weeks before they start breaking down 7. Keep your ozonator working...I upgraded mine to the next higher output. They don't last forever...if you stop seeing bubbles coming out of the jet attached to the ozonator (while the jets are on low, but no air being added), then replace your ozone module.
8. I have the tub set to filter for 8 hours per day...the maximum on our tub. Since I've adopted this mix of methods (lithium chlorite, ozone, Blue), we've never had a cloudy, itchy or scummy hot tub...and our water lasts 2-3x longer.
I still check pH and alkalinity...pH is occasionally out of range and I adjust...but very rarely. I am concerned that my residual chlorine drops to nearly zero between tub uses, so I may start adding a half ounce of lithium chlorite more frequently to keep some free chlorine in the tub.
Feel free to sling arrows at my methods, as they may seem excessive, expensive or inappropriate...but I've finally got things settled down for our tub and the way we use it.
