I'm looking for some advice on my Dimension One Chairman II hot tub. I bought it used and the owner said there was a leak near the heater and was quoted 400 for repairs.
So I got it all set up, electrical turned on, fired it up to evaluate the leak. Decided I needed to throw a new heater in, did so, no more leak at the heater.
Went through decontamination, and finally filled it with what I thought was the final file a day or two ago.
I noticed a few things at that time. First, some of the jets did not work. In some cases, there was no water flow, in other cases it was just drastically less then other jets. In some cases, the inoperable jets were part of a pair of jets, other time they were single jets all on their own.
Second, the flow from the heater (circulating pump for the heater) was very bubbly. Thought maybe this was on purpose. After spending some time soaking, I also realized the circulating pump has 2 outlets into the tub, however the flow is very uneven, with the "bubbly" outlet getting maybe 90% of the flow. While I was soaking, I tried plugging the "bubbly" heater outlet, and flow started coming out of the other outlet faster...however, a few seconds later I also heard some water gushing out the exterior of the spa, or so I thought. I was never able to visually confirm this, or reproduce the sound.
That brings me to the leak. After the final fill, which was late one evening, I opened the spa up the next day and saw that the water level had dropped a few inches. Oh crap. Also, the ground on one side of the hot tub was still wet. The next day, the water level had dropped even more, to the point where the heater had shut off, and I started to investigate.
On removing the side of the tub, it was clear where the leak was located, so I started to tear in. I have pictures below, but what I found was that there was STANDING WATER in this cavity where some of the tubing runs. I ran out of time and daylight to investigate further, but I'd love any advice on the topic of:
Why the jets aren't working, and how to fix them
What can I expect for leaks on this particular hot tub.
Am I looking at repairs so extensive that I should just give up??
Of course, we are also getting a winter storm as we speak and the OA temps are supposed to fall into the single digits. Wish I had discovered this last week, when it was 60 degrees out...
IMG_20151120_170446310 by John Bixler, on Flickr
IMG_20151120_170114026 by John Bixler, on Flickr
IMG_20151120_170108917 by John Bixler, on Flickr
IMG_20151120_170103767 by John Bixler, on Flickr
