sasq40
sasq40's Achievements
  1. This video doesn't show it https://youtu.be/DRRg2_86O2A But this does https://youtu.be/mXlqPHVkKUY Mines a older pump, 2013 so no o ring according to the internet lol
  2. Spa guy on YouTube says use his special silly juice, I'd like to know what I can grab local to use instead of waiting awhile to order something
  3. Also changing out the seal on the valoot side (spelling proably off?) was told this isn't a oring model, but there was silicone on it, what type of silicone do it use?
  4. Went to swap out the impeller in my circulating pump, but it looks like at some point it was changed out. My pump is a waterways cp 1/8 1n22a. According to my research it should have impeller 310-0900 since its before 2015.now the impeller that was it is was a 310-4020. I went to the first local spa place to get a replacement for what I had, which they have me (4020) then I discovered that wasn't correct. Second spa place orders me what was supposed to be a 0900 but comes in at a 4020 and theyre telling me that it will work. The real kicker is that all 2 of the 4020 look different tho lol(top one was what was in my spa pump) can I use these or should I try for a 0900?
  5. There's about 4 fuse in total and all test good using continuity test on my meter
  6. So i'm getting ready to refire my old tub for the fall, had it drained all summer. I knew last year i was having a problem with the pressure switch so i replaced that. So filled up the tub and flipped my breakers and nothing. No clicking, no pumping, nothing in the top display. I checked for power and was getting 240 and checked the fuse and was getting continuity. Worked great all last winter.Its a old artic spa with a Balboa Circuit Board, Duplex Digital, 54003. Any tips to get it working again are appreciated
