Hello,
This is my first post - thanks for having me.
I have a 1999 Hot Springs Grande. I have a leak on the back side (opposite the control panel) down low. It is not the moto-massage unit itself. The leak is not up by the moto-massage unit. But, as can be seen in the pictures, one of the tubes may be involved, I dont know its name, but its the one that goes underneath the tub. Water is pouring out from around this tube where it goes under the tub. The water is coming from behind the brownish colored insulation. I need to do more digging to see whats going on, but I have some questions.
Where does this tube go? Is this is a known type of leak that has happened to others if so, please explain.
Can I flip the tub up onto the front side so the back side is in the air? If so, will the tub stay in position by itself? Would I need to put shims under any portion of the side that will be on the ground to keep it balanced in place?
What is on the bottom of the tub plywood?
How would I get the bottom off are there screws, is it stapled on any tricks to getting it off? Should I take the whole bottom off at once or work in pieces. By removing the bottom, and the foam, following the tube/leak, are the individual components, and the tub itself stable from breaking?
If I missed any obvious questions, please explain to me.
Thank you,
Chip
