Our first tub... 320 Gallon Marquis Coastal Initial levels were before sitting in it first time: TH - 100 FC - 0 PH - 6.6 TA - 0 CYA - 0 After adjustments: PH up & Bromine added TH - 100 FC - 4 BROMINE PH 7.4 TA - 0 CYA - 0 As of Today: TH - 100/200 ISH FC - 10 BROMINE PH - 6.8 TA - 0 CYA - 0 Adjusted Right Now: TH - 100/200 ISH FC - 8/10 BROMINE PH - 7.5 TA - 40/50 CYA - 0 What should we do with the CYA? If we add that first, will it lower the PH also? We still need to add to alkalinity but I think we should adjust CYA first then touch up the rest. Any ideas? We want to get to atleast 200 TH, 8/10 Bromine still, PH about 7.5, TA about 95-120, and atleast 35ish for CYA. What do you all think is best option and what do you suggest to add? Besides something like zorbo maybe a diy project or just buy one for light film and bubbly tub we are now getting. Story Behind the Tub: My wife and I found a tub for sale. Three mths before it was $800, two mths before it was $600, month before it was $400 and then two weeks before it was down $200 so I called. We sold our 5.5 ft round tub and was looking to upgrade to this 4-5 person tub. We agreed with seller (Thurs) to pick it up a couple days later (Sat) when I had a truck, trailer, and helpers. On Fri the seller calls to tell me a person before me was coming to take a look at it on Sat. If they dont take it, then the tub is mine to buy for $200. I politely accepted. I call off the helpers on Friday night and let them know we might need them anyways. Sat I get a call an hour after I was supposed to pick it up and the seller fills in me that the wood base is trash. The seller still asks me for $200. After being told I can buy it then not then I cant then I can plus cancelling my help plus recalling to borrow the truck/trailer; I negotiated a FREE tub for us with the seller. We were told it had a leak, base was shot, and the panel needs a new cover on it. After setting it up at home and replacing base, I found the leak on the drain hose valve. Removed that and leaks were gone. I looked over paperwork. They had spent almost $7000 on the tub originally plus $$$ to maintain it with pump and jet work over the years. We had it wired by certified and insured master electrician then filled it. Number of hours later we tested it and adjusted levels best we could. We had used it almost every night for 6 weeks until my wife had our daughter. The seller had calcium build up around water level. Some very thick smoothed over and bumpy spots also. We thought this wouldnt bother our levels.
