Spa Problem - motor
I have a Balboa spa pack. the 2 speed pump is not working but the 1 speed pump - pump 2 - is working fine. what i have done so far is changed the capacitor and checked the voltage to the pump. I have all voltage to the pump as perfect. here is another issue. In order to see if the pump was working, i took the wire on the spa pack that says pump 2 and switched it with pump 1. when i did that, the 2 speed pump came on when activated at the control panel.
so i know the pump is good, the control panel works fine for everything. the red dot even lights up when pump 1 is activated, its just the pump doesn't come on.
I could really use some tips here from you guys that have more experience. i am pretty fair with DIY and using volt meter.
Thanks in advance for everyones help.
Harold...
