Hello Spa Gurus,
You guys are awesome. I love reading forums where the membership is as supportive as yours is; good stuff!!
I have what is quickly becoming a "vintage" hot springs hot tub.
It has an IQ2000 board and is connected to 110v 20A service.
Everything was working fine when we started to get some red blinking light failures. I would unplug the spa, it would reset, and we would be back in business.
Recently, my daughter and I cleaned out the filters and put it back together and got another red blinking light. This time, however, the LCD panel would flash all of its icons and then stop displaying anything at all.
Now the spa will not heat, I cannot read anything on the display board, but the circ pump stil works.
The tattletale LEDs indicate to me that the thermistors are in range, that the main board is NOT calling for heat, and that the LCD control panel is plugged in.
I'm not a stranger to electronic repairs but I was hoping for some educated instruction before I started throwing parts at it...
FWIW it looks like I need to do the upgraded valve install with the loop built into it... It appears some small amount of water has been leaking in to the control area via the top air valve...
Any suggestions, guys?
Thanks in advance!
