Wait. Doc said if done right it can work. But whats funny is we know full foam works and there are very very few leaks which those not full foaming use as their scare tactic. And we never know if non full foam works. We do know it's cheaper and we do know there is 1 or 2 manufacturers that know how to make it almost as good as full foam.
You need some schooling in natural science, sir:
Full-foam is just a process left over from antiquity manufacturing processes. In fact, foam cannot physically recover and use waste heat. Neither can foam conduct heat better than free ... air. The Aspen Spas insulation system makes use of a thermal barrier (heat sealed), generated by waste heat rejected from the motors and pumps, in an enclosed air cavity around the tub. It is physically superior to a full-foam system which simply insulates the tub directly.
Now, back to cost-efficiency:
Air is 1341 times less expensive to heat than water. What doesn't conduct heat are the layers of aluminum and other insulation trapping hot air beneath your Aspen Spa. And if you are heating the air to form an air barrier to stop the super high watt density or BTU's per cubic foot of water, you will automatically save energy, even if you only have 3/8 of an inch of wood and no thermal foil and no foam insulation at all. As stated previously, Aspen Spas have much more thermal sealing than this.
So, have fun with your boring, old low-rent fully-foamed spas. Aspen Spas are scientifically designed to be more efficient.
