Appreciate the quick reply!
Decided to start over, draining and refilling the tub. Learned a lot from this thread and decided to start clean.
Is there a preferred order in regard to balancing the water? I know that adding salt should be last but what about FC, PH, alkalinity and hardness? Does it matter which you do first? Understand that AL and PH are interrelated...
Also, should the tub be at temperature before starting any of the tests? Or is it inconsequential?
Thanks!
