Chas:
Thanks much for your reply.
OK, so while our tub doesn't seem to have the bleed hole you described, we were able to verify that the circ pump seems to be functioning well. The tub has a little "waterfall" that you can engage with a valve, and it's flowing out of there very nicely. Dad says it's never been any better than that, I'm going to estimate that flow in the gallons per minute range.
We do have the heater with build in pressure switch. I have jumped the contacts on the board as suggested, and then sure enough the relays pulled in, the "heater on" light came on, and we were able to verify that the tub began to heat.
Now armed with a multimeter, I checked the contacts on the pressure switch for continuity, and it read nothing, so I'm guessing that you've helped us identify the problem.
Sounds like a good do it yourselfer can replace the pressure switch. Question is then, where can I get the pressure switch? Part Number?
Thanks alot for your help so far, this is just what we were trying to avoid was a service call and expensive replacement parts. Thank you!
RR
