okay I found that valve, so the only way to shut it off is the T valve which is on the opposite side which will shut off all water going into the pump on the opposite side
Im sorry it never had zero flow it has no pressure from jets always had flow just limited pressure Thanks
No valves on or near pump other that T valves used to turn off water flow to pump . Not sure what an ozone jet or footwell is sorry just an amateur with a owners manual or schematic.
No, just asking, I thought the blower was just for the bubbles in the seats right? Just wanted some trouble shooting ideas dont even know where to begin. Had 1 suggestion to check the impeller, to see if was worn down. The pressure is better closer to the pump side of tub.
meaning?? My control board is simple on/ off, heat and circulate thats it no read outs at all . Any idea how to check if somethings not working I dont even no what to check .
I have a VERY VERY old Leisure Bay hot tub that seats 6-8. No model # on it( bought it used). 7ft x7ft currently has a 1hp pump. Replaced O rings on jets, it had a new pump that flows well and circulates water nicely. However, water not going forcefully thru jets like our old hot tub. This tub has no BLOWER!!! it was disconnected. I dont know what size pump or blower is required on this size tub since I dont have a model #. Any help would be greatly appreciated. Thanks so much.
