FYI: Because this answer wasn't anywhere that I could find, here is the solution to the locked display:
Test the two hot leads feeding your main board and make sure the voltage is correct. In this case, 220v. ***(Please make sure you are competent enough to do this without killing yourself! Your life is not worth an $80 service call by a professional)***. My voltage was only 110 to the board due to an incorrectly wired emergency shut-off box.
Test the breaker box to see that both load wires are carrying 220v. If they are not, call an electrician to fix the problem, or (again, please don't risk your life) fix it yourself after shutting the breaker off at the house.
I hope this helps someone in the future!
