We had a Hot Springs Classic spa for 21 years but leaks developed so bad that it was not cost effective to keep it so we replaced it with a used 1999 Classic F because my wife uses it daily for water exercises to help her arthritis and new hot tubs no longer have the open construction of the Classic.
I have the 2000 board and I checked and the red heater light was on. The small pump was pumping vigorously, and the jets worked normally.
The heater stopped heating after six month. It is the three-fold trumpet kind. I ordered the replacement heater 73790 with a length of 20 inches.
I suspect the cause being that the water level was low, below the decorative stripe and the middle filter was quite dirty.
1; The new heater is longer than the old one and if I can shoehorn it in, since it hits the wall on the left in the compartment, the hoses will not reach by about two inches. The hose to the pump has no clamp on the plastic T-pipe above the pump so I can’t replace the hose, can I somehow extend that hose, the same with the second hose. Another solution I can see is to angle the heater up at a 45 deg. angle to get the business end closer to the hoses but that would not allow me to fasten it down, it would be free floating. And in that position would it fill with water on start-up?
2; I have new sensors which plug in on the right side of the board, are they interchangeable or do the thermostat and the high limit control go into dedicated plugs.
Tomorrow or Wednesday I will do the work and will be back if I run into trouble.
Regards.. …..Ott
