I am looking for some help with my Amore Bay D1 spa. My control panel went out about three weeks ago and I was able to order a new one. Got it installed fine and everything seems to work, except for one thing. Just like always, I removed the bleeder plugs on each side of the spa before I re-filled it with water, so the air would escape the lines while filling. After I filled it I ran the pump for a few seconds and everything went just as before. Once I knew the jets were running ok I screwed the two bleeder plugs back in. The one hole that is next to the circulation filter went in just like before and no issues. The second I screwed the one in next to the main filter I immediately got a low flow error on the display and the heating process stopped working. As long as the error is there it won't heat up. I unscrewed the bleeder plug out again and the error went away and everything worked perfectly again. The only difference I see is that the bleeder hole on the circulation filter side does not have any water coming out of it, when open, and the pumps are off. When the pumps come on water then shoots out of it. The bleeder hole on the main filter side has water shooting out of it, when open, regardless of whether the pumps are or or not. I can put the one bleeder plug in on the circulation side and all is still good. The minute I screw the other side in the low flow error comes right back on again. I can leave the plug out on that side and everything works great, except for the small about of water shooting out of it. I just don't know if leaving this plug out will cause other damage? Any thoughts or ideas would be most appreciated.
