I have a 1995 Dimension One Diplomat that is indoors with a room/addition built around it. I am not the original owner/builder, like the screen name says, the hot tub came with the house we bought 4 years ago.
I have noticed some wet spots on the wood case, fairly even with the location of jets. This is not condensation from the cover as the spots are only wet in that area. Am I correct that these are probably jets that need tightening?
As you can see there are stairs that lead up to a elevated floor on two sides of the hottub. More than half of the tub is covered by this floor.
With the tub built in place as it is, can someone please recommend a solution for me? Do I cut the wood side trim off and try to replace it with an access panel? Do I try leak-stopper knowing the problem is likely the jets and not the tub itself?
Thoughts?
Thanks
