We have a 2000 Coast Bahama Millenium but I think it might be time to replace it.
It has been running continuously for almost 12 years (this summer) and we have loved it. FYI - this is a cold weather location - North Wisconsin. Very few problems.
- replaced circuit board (no cost - covered under warranty)
- replaced 1 pump
- fixed some leaking gaskets last spring after a leaking problem
This last problem has led us to believe it needs to be replaced. Technician said the gaskets were corroded and there may be more with the problem but fixed the ones that were leaking. Now have another leak that has drained the tub. We have not had anyone to look at it yet. Not sure it is worth the service call.
So I have started to research what we might replace it with and have come up with the following:
Sundance Optima
Beachcomber 750
Hot Springs Grandee
Coast Bahama, Freedom or Manhattan
We have not done any wet testing or even seen these in person yet. We have contacted dealers in our area via email. The Sundance, Beachcomber, Hot Springs are all available from dealers within 45 miles. The Coast is a bit further but is the company that has done service on our existing tub (but did not buy it there).
What is important to us:
- good massaging jets
- comfort
- foot massage jets
- tub for 6+
- quality
- good cold weather efficiency
What we don't want:
- lounger
- audio system
- special water features
Questions:
1. Is the beachcomber hybrid a good choice for cold climates?
2. We currently use bromine - and have no problem with it. What are the advantages of some of the newer systems - Salt?
3. Hot tub will be surrounded by raised decking on three sides so only tubs with one sided access panels will work - I think all of the above fit that.
4. Are any of the above easier to winterize (or leave unattended for 1-2 months). We have never winterized before we have always kept it running but know that the next couple years it will have limited winter use because it is not at our primary home.
